Did I mention that it was my wife's first time on board?
Next challenge was getting the boat back on my lift without having anothe person on the bow to control it coming in. I have a pretty sweet set up at home but maneuvering the boat at low speeds and controlling the bow is not easy. Trying to compensate by going in reverse doesn't seem to work like it did on my previous boat. Any hints or directions to previous topics would be welcome.
http://i7.photobucket.com/albums/y286/D ... at1mod.jpg
For my next trip, after setting up the boat for singlehandling (see story above), I headed out into to be met by 25 MPH wind (the forcaster had predicted 10). Should have gone back in but I'd taken the afternoon off and rain was forcast for the next few days. Not the ideal conditions to try singlehandling but it worked okay. Kept the main depowered and my hand on the mainsheet to accomidate the gusts. As the wind continued to pick up, I figured that I might be pushing my luck. Did a relatively controlled gybe to head back. The term relatively is operative as the aluminum pop rivets holding the boom to the mast sheared off. Boom and main in the water, 25 MPH winds, 4 ft chop. Not so good. Got home fine but the kind of excitement I really don't need. A good thing the wife wasn't there.
The part in the manual of no equipment failures is dead wrong. The gybe was not a terribly violent one (there was no damage to the main for example) and to have a fairly important part of the boat literally come apart does not inspire confidence. Instead of rivets, I'm looking at tapping the holes and using stailess steel screws. This should provide more strength but I am concerned about the screws damaging the mast when I get into heavy weather again. Thoughts?
It will only get better.
Thanks
Dave U [/url]
