Similar to MacGregor?
robh2
Post by robh2 »
Looking at a few 26x/m models and someone mentioned a similar boat made in Europe I believe it was, that is 28-30 feet. Anyone know the name of the boat? He said it was like a copy but larger.
Thanks.
Re: Similar to MacGregor?
Post by K9Kampers »
You're likely thinking of the Imexus 28. They also have a 34 and a 37
Imexus Yachts
FLGSHP7
Post by FLGSHP7 »
Interesting. However, the 28 model seems a little sparse on interior amenities in comparison to the 26 M X
robh2
Post by robh2 »
Thank you. That was it.
I appreciate it.
sailboatmike
Post by sailboatmike »
I think a few people have tried to clone the 26X, 26M.
None have made a fist of it.
The Mach 28 (seems a familiar name) is a dead set 26M clone, including interior setup, the killer was the $90,000Au price tag, thats $60,000 US$
Here is a second hand one for sale at the bargain price of only $75,000Au or $50,000 US
http://www.powersailermarine.com.au/ind ... 34:forsale
kadet
Post by kadet »
I always thought the Odin was the nicest of the Mac clones :)
http://odinpowersailor.weebly.com/deacs ... pdate.html
kurz
Post by kurz »
kadet wrote:I always thought the Odin was the nicest of the Mac clones :)
Oh I like the permanent mast raising system. Not mess with the Mac MRS around, no pulling down the Genoa to put the pin in...
And lot of stowing room inside ...
Cougar
Post by Cougar »
Odin and Imexus are the same boat. Don't know why they have different names in different countries.
bobbob
Post by bobbob »
That MRS uses the front furler to raise the mast? I have often thought of such a thing on the Mac but it seems to me the angle is all wrong to be pulling from the top of the mast - an awful lot of force is pulling parallel with the mast when it is close to being fully lowered. How does this boat solve that problem?
kadet
Post by kadet »
Cougar wrote:Odin and Imexus are the same boat. Don't know why they have different names in different countries.
Same as the Audi A3 and the Skoda Octavia are the same car, a VW A Platform, but I know which I would rather own.
Originally the Odin was designed for the German market so had better finish and fittings unfortunately they did not make a go of it and Imexus from Poland is all that is left now I believe, it was a joint venture between two old :macx: dealers Volker and Gerda Lamprecht (Germany) and Andrjez Palarz (Poland).
Well truthfully after dieselgate I would not want to own any VW product :)
kadet
Post by kadet »
bobbob wrote:That MRS uses the front furler to raise the mast? I have often thought of such a thing on the Mac but it seems to me the angle is all wrong to be pulling from the top of the mast - an awful lot of force is pulling parallel with the mast when it is close to being fully lowered. How does this boat solve that problem?
Big A$$ mast crunch :)
kurz
Post by kurz »
Hi Kadet
thanks, looks interesting.
So do they have not lines to secure the mast from bouncing port to starport?
kadet
Post by kadet »
kurz wrote:Hi Kadet
No they have baby stays same as the :macm: you can see the starboard one dissecting the mast crunch in the photo.
kurz
Post by kurz »
actually we could adapt this system to the :macm:
Just install two pipes at the side of the mac but same place than orig MSR.
For storing you put tis 2 pipes (form adapted to the boat) on the deck, the hinge is at same place like MSR, but at the side of the boat.
to use you take the 2 pipes up, screw them together click in the winch or pulley blocks if your prefere, and go with the line at the same place to the mast like with org MSR.
Advantage: No hassle storage under the boat :D
I would love it...
These look like the baby stays. Hard to tell, though.
