BOAT wrote:Hey Tom, what's is the chain for? Why do we put chain on our anchor? I always put lots of heavy chain on my anchor because that's what I was taught to do but why do I do it?
Uh, because you were taught to?
BOAT wrote:Is the chain there to hold the anchor down so it does not pull out of the mud?? I'm not an anchor expert.
Neither am I. And among the experts, there seems to be no end to the disagreement.
Mac26MPaul gave a pretty good summary of the points I was going to hit, so I'll only mention that even though heavy chain provides catenary (the sag a rope or chain takes), which provides a bit of softness as the boat pulls in a regular cycle, it's only good up to a point. Pull too hard, and it will go what's referred to as bar-tight (like a solid rod), at which point it will fetch hard.
That's rough on the chain, and on the termination on the boat, and for that reason a snubber should be used. Cruisers usually use a long length of three-strand nylon, with enough chain slack to prevent fetching.
In theory, if you used a mile or two of chain, you wouldn't even need an anchor. But remember that the harder you pull, the more chain is lifted off the bottom, and the less friction is available to prevent the chain from sliding along the bottom.
A long, heavy chain means you can use a smaller anchor, but the harder you pull, the less chain is on the bottom, and the more the anchor has to hold (once enough chain is up that the rest starts to slide). When the chain goes bar-tight, it's all on the anchor. So for a small boat, I would opt for more anchor and less chain. And I wouldn't use all-chain rode unless I had a windlass, both for the weight, and for the need for a snubber. Paul's needs are different, of course - more like that of a mooring. But for a trailer boat, used as such, three-strand nylon and a good anchor of adequate size is the way I would go.
'Would', because my FX-7 is too small for the boat for full confidence in a blow, though it will dig into mud to where I can barely get it back out (with flukes set to 45 deg), and easily disappear in sand (flukes set to 32 deg), but the FX-11 would be a better choice. The larger one won't fit the anchor locker unless I cut the stock short. I've kind of decided not to upgrade to a Rocna or Spade type, as I'd need a bow roller, and that'll give me some grief on the trailer. And with the bicolor sidelight unit on the bow (lotta work to relocate one to the underside of the bow rail). So I think I'll just stick with the Fortress in the anchor locker, and my trusty Bruce knock-off, which also digs in nicely into the bottoms under my local waters (I store it below decks, ready to deploy). A a big, heavy Danforth, also stored below decks, with chain and 1/2" nylon, ready to go (a real finger biter, that one).
And I have an anchor alarm on my phone (Drag Queen).
