New Jib Info
Ricky
Sailboat: MacGregor 19
New Jib Info
Post by Ricky »
I just picked up a :macm: and the jib is disintegrating since it was left out in the sun for over 2 years. I need to buy a new one, most likely from Judy B as I've read a lot of positive feedback here on the forum. Any recommendations as far as size and options to get? These are the ones I'm referring to:
https://www.hydesailsdirect.com/Macgreg ... /38928.htm
I'm in SW FL and will mainly be sailing this area. The boat will be kept on the trailer most of the time.
Thanks in advance!
Re: New Jib Info
My advice is to contact Judy directly - her phone number is on the website - and get her advice on what set of sails will best suit your conditions and expected usage. She's always eager to help and she knows her stuff.
Re: New Jib Info
If the sail has a UV cover, it's likely the stitching is rotted, especially in a Florida sun. It can be repaired relatively easily. If it's the UV cover. :wink:
Baha
Re: New Jib Info
Post by Baha »
Another vote for calling Judy B...her stuff is great and she will work overtime to get you what you need for your area and sailing preferences.
