I'm actually very interested in the ability to tune the shrouds. With the factory rigging, I couldn't see using a Loos gauge. I keep it where Supersport Marine set it the initial time we raised the mast. To me, it seems that it should be a bit tighter but I cannot adjust the shrouds to the next hole--way too tight.Phil M wrote: Suggestion: You might want to investigate a Johnson quick release lever, especially if you tension the stays with a Loos gauge.
Is this the lever to which to refer? https://www.westmarine.com/buy/c-sherma ... oCvK_w_wcB
I just replaced the shrouds last year with a new set from BWY. To install the Johnson lever, do you have to re-work the shroud length? Are special tools required?
Thanks!
Doug
