sailboatmike wrote:Thats my experience with the X it hardly moves when I step on before filling the tanks and Im no feather weight (90Kg or 200lbs)
Look at the photo carefully notice the scallops in the captains seat, mine is real early production and doesn't have those, so I presume that may be a prototype in the picture
Okay, so you have an X boat and according to you I am not just seeing things - I'm telling you guys that the M boat is WAY MORE rolley polly than the X boat -
That must be why I hear all the X drivers getting into a panic at 35 degrees - it probably feels really bad to you guys - it's just normal daily business on the M boat.
I bet if Tom had the data the GZ curves for the two hulls would have differences like illistrated below - most boats have a little hiccup right after the Maximun Righting ARM - the M boat does not.
This is pretty typical from what I have seen on a lot of boats - they seem to get a little spot of acceleration right before they put the chine into the water.
You can see it here on the Bavaria 32 also:
I think the M boat would have a less steep initial angle like the second picture below but I think it would have a WAY flatter top on it because the boat hits a wall at 45 degrees.
It would be interesting to get a GZ curve calculation from Tom - if only we could get him the data - it would be VERY helpful in sailing the boat at it's best performance.
