Spinnaker
Re: Spinnaker
Small asym with a sock.
Anything above 160 AWA you will be faster with your Jenny poled out. You will not look as cool.
From 90 to 160 AWA will be your point of sail where it will probably give you more speed.
- sailboatmike
Re: Spinnaker
Has anyone put a spinnaker bow sprit (prodder) on their X, I see BWY has one for the M, but it says M Model only, not sure what the difference would be
http://shop.bwyachts.com/product-p/3805-1m4.htm
paul I
Re: Spinnaker
The difference is probably the way it mounts to the anchor roller.sailboatmike wrote:Has anyone put a spinnaker bow sprit (prodder) on their X, I see BWY has one for the M, but it says M Model only, not sure what the difference would be
- March
Re: Spinnaker
We attach it directly to the pulpit, I'm sure it's not the best configuration, but it works pretty well
Re: Spinnaker
They're very different. And the aftermarketpaul I wrote:The difference is probably the way it mounts to the anchor roller.'s didn't come stock with an anchor roller. They are an add-on accessory. And I am not sure if the roller used on the
is the same thing.
Re: Spinnaker
I put an anchor roller on one side and sprit on the other. The sprit could be removed. It was attached in 3 places, bolt through to the side of the anchor roller, bottom forestay tang hole, and stainless bow cleat. Used it for a drifter and spinnaker.
- sailboatmike
Re: Spinnaker
My anchor roller looks very much like the M roller, its offset to the starboard side, just dont have the rear lugs for the BWY bow sprit
