I assume it's plywood, but would love your expert advice and opinion if this could be easily fixed.
I'm looking to buy a MagGregor26 (
One particular 2012 M which I am interested in has a soft spot on the portside near the mast, and it worries me. It has several parallel cracks in the gel-coat near the mast, which can be seen from the photos here: http://imgur.com/a/tnPlh. The cracks are left and right from the non-skid area above the front window of the portside, and the deepest cracks are next to the mast.
I have no idea how old the cracks are, but an area of approx. 40x40cm (16x16”) is pretty soft and makes a crackling sound when you step on it. (I’m well under 80kg / 170 pounds, and I’m very concerned about both the flex and the cracking sound from the fibreglass), as this may lead to much more damage if left unrepaired.
On the same boat, the starboard side next to mast is much stronger and there’s almost no flex. Maybe it’s because the vertical timber compartment from the head serves as a stable support from underneath, or maybe there’s just no moisture or damage inside that part of the deck. In any case, I’m worried about the soft deck on the portside.
Q1) If there is a soft spot on the deck (portside next to the mast of an M), is this normal or should I expect rotten plywood underneath?
Q2) Looking at the cracks left and right of the soft spot on the deck, should I stay away from this boat, or is there a proper and long-lasting way to fix a soft spot?
The boat is not a bargain (not at all), but one of the few M's nearby, so I'd really appreciate your advice if this a deal breaker.
Rob
