DaveC426913 wrote:BOAT wrote:
I assume your already starting with way too much sail horsepower on the rear of the boat - you need to get more sail power moved forward and get that boat balanced.
I have been doubting whether simply moving the ail forward should make a difference. While
sail area may be moved forward, the
sheet/cleat has not, and is therefore pulling from just as far astern in both cases.
So I had to draw up a diagram to understand it.
It seems that moving the sail forward
shortens the distance through which the pulling force of the sheet/block/cleat can act. In the diagram,
A' is shorter
A. Like using a long-handled wrench versus a short-handled wrench, the long-handled provides more torque. I want
less torque. So I want the short-handled wrench.
Wow, okay, for the third time guys,
Remember? I said:
"The fact that your main is a 4:1 block should be a hint to you as to how much horsepower is really coming from that main sheet . . . . . . . The Genoa sheets are pulling directly on the back of the boat too . . . . . . . I suspect it would help the X boat to move more of that mainsheet “pull” towards the mast by transferring it with a boom Vang . . . . "
I did not say to move the SAILS forward, I said move the sail POWER forward.
Maybe if I say it differently: The POWER of the sails is transferred to the boat by the stays, the mast, and the sheets. To move power you need to move THOSE THINGS, NOT THE SAILS.
It's pretty hard to move the stays or the mast, so all that leaves you with are the SHEETS.
Again, Moving the sheets forward is a possible remedy, or another possibility is a bowsprit - sometimes a bowsprit can help move headsail power out in front of the boat.
If your using a smaller sail in the same cleats your not moving the sail power at all.
All your doing in that case is reducing the overall sail power. Also, in the diagram the first boat has more force pulling the stern than the second boat. The second boat has more force pulling forward than the first boat, there for the second boat in the picture would round up later than the first boat - I think that sort of contradicts your conclusion.
Something is pushing the back of the boat away from the wind - it's either THE WIND, or it's the shape of the hull.
