ballast freezeup
ballast freezeup
Has anyone ever had their MacGregor get stuck in ice? I live in New Bern NC and we recently had ice formation where I keep my boat in the water. A week previous to this the temperature was balmy and then the next week we had temps in the single digits at night. It didn't occur to me to blow the ballast that balmy day and my boat got stuck. The ice wasn't that deep and I think the ballast is somewhat below water level where it hadn't frozen. Anyone with any experience with this. I worry about the ballast freezing and causing some damage when the ice expands.
Danhux
Re: ballast freezeup
I live In Raleigh, it got cold enough to turn the water in the head to slush before I remembered to fetch it off the boat. What happens to the head and contents if it freezes then thaws? How thick was the ice on the water?
- yukonbob
Should be fine. You would need to freeze the ballast tank solid in order to do damage. If you’re really concerned you can pour potable antifreeze in to reduce the freeze temp of the water.
Or pour some rock salt in there. Maybe even some around the boat where it's freezing to melt it.yukonbob wrote:Should be fine. You would need to freeze the ballast tank solid in order to do damage. If you’re really concerned you can pour potable antifreeze in to reduce the freeze temp of the water.
I think it was about an inch thick. I couldn't determine exactly. I went out to the boat on Friday and didn't see anything unusual.
More importantly, have you checked the consistency of the water in the ballast? Is it slushy? Is it solid? Is it fine? You are obviously concerned, but have you done your own due diligence?
- yukonbob
An inch is getting up there. I woudl also start to get concerned. Might be time to take action or haul it.
- John Brosda
