Replacing Standing Rigging... are all SS cables equal?
taylormade
Post by taylormade »
I'm ready to redo the rigging. I'm looking at BWY and they offer a complete rigging set for the X for $325. That includes new stay adjusters swaged on and the full monty, aside from shipping of course. http://shop.bwyachts.com/product-p/3118-1x0.htm
The thing is I have all the hardware and the swaging tool needed for the job. I just need the cable. Even if I were to buy it at the local "Worst Marine," I'd be out of there for under $150. I've found 100' of stainless cable online for well under $100.
Is there anything I need to be looking for aside from T316 1x19 5/32" cable? Am I making this too simple like I do everything else?
Signaleer
Location: Foley, Alabama...2002 26x & 2002 90 HP Mercury Salt Water 2-stroke
Re: Replacing Standing Rigging... are all SS cables equal?
Post by Signaleer »
Ok, I have done this a few times now.
Please - do yourself a favor and use turnbuckles. I am usually a die-hard mac-original guy... well, don't be.
Balancing this rig with those original things is a pita.
1X19 is fine, I got 250 off Amazon for somewhere in a 100 bucks. Any west marine will have a crimper - or you can get one like I did.
I will be honest - this aint easy, if you want to get the rig tuned right.
Enjoy yourself.
Ed
taylormade
Signaleer wrote:Ok, I have done this a few times now.
Thanks for the reply and advice! I have a crimper already and I also have turnbuckles on all the stays from the previous owner that I planned on reusing. Do you have any recollection of how much cabling you actually needed? I was thinking 150' would be plenty, no?
Signaleer
Post by Signaleer »
I bought 250 spool... but yes, 150 will be more than enough.
I have a different mast and shorter spreaders - but my uppers were 25 feet apiece, and lowers were like 14 if memory serves me
Stock lengths are probably 26 plus or minus I'm guessing.
I used the stock 5/32 for shrouds and already had 1/8th forestay created last year that I reused.
Ed.
taylormade
Got it, thanks much. I'll try to source 150'
taylormade
Signaleer wrote: Please - do yourself a favor and use turnbuckles. I am usually a die-hard mac-original guy... well, don't be.
Ed
Actually when I checked (sigh, it's been too long since the sails were raised) I only have turnbuckles on the front and rear stays. Are you advising to put them on the sides as well? Sure would be a lot easier and more precise than adjusting holes.
DaveC426913
Post by DaveC426913 »
I've never adjusted my stays. But I prolly should.
If I were to replace the current adjusters with turnbuckles, would that require replacing the SS too?
Signaleer
Post by Signaleer »
Well, let's get the facts out.
The existing hardware will work. It is on my boat now.
I probably am a bit ofa sailing snob for the Mac community and want the rig tuned tight and like pushing the boat.
I've replaced the entire rig twice now and when I put a cabon spar on it - it will have turnbuckles. Tuning the rig with turnbuckles on shrouds is 1000 times easier and faster.
I have read turn buckles down travel as well, but I keep mine on a life (soon) and for now, in the water.
This is just an opinion - I'll never NOT use turnbuckles again. Based on my experience.
Ed
taylormade
Alright, what about cable ferrules? I'm beginning to understand why BWY is charging so much for their pre-mades... what a pita it is to find all these components! When I thought I finally found what I was looking for, I noticed that it doesn't specify use for 1x19. Are there specific ones just for 1x19?? If so, can anyone post a link to where I can buy them? Thanks!!
Estate Sail
Post by Estate Sail »
I just replaced my standing rigging on my 26M with a BWY Kit for $300 with shipping. They do a nice job and give me peace of mind that it was done right. I had a main shroud fray with only 6 strands remaining. I don't know if I would have lost the mast if it completely but it scared the crap out of me.
taylormade wrote:Alright, what about cable ferrules? I'm beginning to understand why BWY is charging so much for their pre-mades... what a pita it is to find all these components! When I thought I finally found what I was looking for, I noticed that it doesn't specify use for 1x19. Are there specific ones just for 1x19?? If so, can anyone post a link to where I can buy them? Thanks!!
Those are stainless. Copper is normally used for these terminations (not aluminium like those in the big box stores). You'd probably need a much heavier crimp tool for SS.
taylormade
Estate Sail wrote:I just replaced my standing rigging on my 26M with a BWY Kit for $300 with shipping. They do a nice job and give me peace of mind that it was done right. I had a main shroud fray with only 6 strands remaining. I don't know if I would have lost the mast if it completely but it scared the crap out of me.
Yeah I get that and I can CERTAINLY appreciate the ease of it... believe me. But from the looks of it, I can buy the raw material for $155. I already have the crimper (swaging tool) and I'm afraid that if I buy the pre-made ones, I'm going to have to adjust them anyway because I moved all my hardware (spreaders, blocks etc) over to a new mast so it might not be the exact same and I may have to adjust them anyway.
Signaleer
Post by Signaleer »
taylormade wrote:
Estate Sail wrote: But from the looks of it, I can buy the raw material for $155. I already have the crimper (swaging tool) and I'm afraid that if I buy the pre-made ones, I'm going to have to adjust them anyway because I moved all my hardware (spreaders, blocks etc) over to a new mast so it might not be the exact same and I may have to adjust them anyway.
Very smart.
Inches matter. If it is the exact same mast and all the exact same hardware, maybe it would work. its a lot cheaper to do it yourself, although be prepared - this is not a single six pack job.
I learned more about rigging, rake, bend, tension (get a loos gauge... seriously, get one) and other crap I never want to know about. OH... and I wish I used turnbuckles.
Fair winds.
Ed
kurz
Post by kurz »
yea... do it yourself gives you a hard start. BUT later it goes well.
I like to have the know how. And if something has to be repared... just do it instantelly ore make it better.
Example: One lifeline was broken. So now have enough 3mm cables to do the next one. And IF I will do the other side, I will put crimps also there where the cable goes through the stanchion to prevend damage.
taylormade
Well for anyone looking at doing this, it turns out that 150' was NOT enough for me. I ended up being two feet short on the last cable I was going to make (lower side stays). I wanted to redo everything including the baby stays and I ended up being just short of the lower stays. I'll reuse my old cabling and make the baby stays work no problem, but I have to buy 25' of cable for the lower side stay and finding it at a decent price point is not easy nor fast. Shoulda bought 200' D'oh!!!
