Dow Corning® 795 is a one-part, medium modulus, neutral cure silicone formulation. Dow Corning® 795 cures to a durable and flexible silicone rubber building joint seal, and can accommodate ± 50% joint movement in a properly designed joint.
± 50% Joint Width Movement
Medium Modulus Building Sealant for Expansion Joints
Structural and Non-Structural Glazing of Glass, Metals, and Plastics
Basic Use: Structural and non-structural glazing of glass, metal, and plastic; adhering stiffeners to building panels; weatherproofing applications, including perimeter sealing of doors and windows. Dow Corning® 795 is virtually unaffected by sunlight, rain, sleet, snow, ultraviolet radiation, atmospheric contamination, ozone, and temperature extremes. Joint performance does not change significantly with aging or exposure to weather.
NOTE: Should not be applied to building materials that bleed oils, plasticizers or solvents, or in totally confined spaces. Do not apply to frost-laden or wet surfaces, or to surfaces that are in direct contact with food. Check cartridge label and Specification Data Sheet for additional limitations.
Ref:
http://www.crlaurence.com.au/crlapps/sh ... odelID=597
