96X ballast vent assembly
Dawgfish
Post by Dawgfish »
Howdy all!
The all thread valve midship under the step seems to be ready for replacement, I’m looking for info about this assembly, I don’t see any thread with this so far, please help ! I found it was broke when showing it to a buyer, moderately embarrassed about it.
Dawgfish
Re: 96X ballast vent assembly
Post by Dawgfish »
Ha don’t know why I asked before hitting up BWY....
Anyway here’s the link
http://shop.bwyachts.com/product-p/h202-1x1.htm 8)
Don T
Post by Don T »
Hello,
When installing the valve make sure to bend the rod so that the plate and seal are parallel to the hull. It will seal better with less tension.
good luck
Dawgfish
Post by Dawgfish »
Oh ok! Thanks for the heads up!! I have to do this afloat (difficultious- maximus).
Any idea what angle ? A ballpark figure ?
paul I
Location: Niagara Falls, NY 2000 26X w/Honda BF50 "NoneShallPass"
Post by paul I »
I never realized there ever was a second valve until your post. My :macx: is year 2000. I had to do a double take after I saw the Pic from BWY. I felt better when I read it and saw it had been discontinued in later models.
Dawgfish
Post by Dawgfish »
Interesting, I’m going to bond this to a zinc and keel strap.I’m sure galvanic current plus partially sealed stainless broke the bolt from the weld on the plate. The keel strap broke several years ago.its probably ready to be changed again.
Don T
Post by Don T »
Dawgfish wrote:Oh ok! Thanks for the heads up!! I have to do this afloat (difficultious- maximus).
Can't help with the angle. I assume all hulls and steps are slightly different. It's easy to see the mating surfaces when it's on the trailer.
