Forecast was for wind. Left the main covered, boom lashed to cabin. Set storm jib only once out of harbor (Caesar creek, Fl. Keys) speed on shallow reach, 3.5 knots. Board down, needing to clear shallow area. appreciable leeway. Heel @ 20 degrees. Helm light. Clear shallows, turn more down wind. Speed, 5 plus in gusts. Averaging 4. Board pulled up. Course stability good. Note yacht has added skegs installed for this occasion. Helm light, mushy, but responsive. Wind whistles in the wires, heads beginning to be blown off whitecaps. Handling improves at 5 knots and Over. I’m a bit under canvassed but it’s too windy for double reefs. I need a trysail. I vow to acquire one. Best course regarding wind and sail handling has me seaward of rhumbline. Jibing the yacht is easy with the small jib. Both running backs are set up. I can jog the boat on the opposite tack without much effort, to cross back over my rhumbline. Towed kayak surfing is an issue. Fix that by tying plastic water jug on length of line and looping that over the kayak towline so the water jug trails astern of it. It prevents its misbehavior. Boat feels good and in control and is able to be brought to a beam reach for allowing a break from the helm. She will mind herself, although make heavy leeway, like this. No progress to weather could be made, though. Were conditions to worsen, the largest danger would be the kayak. I feel that in larger seas, eventually it would turn over, submerge, and be lost to a broken towline. I would put the engine down in stronger conditions. The running backs instill a bit of confidence. In larger waves surfing the yacht would become probable. I would fear losing control briefly as the wave passes under the yacht, due to having no keel. Also, while I experienced little strain on the steering, the waves today were minimal. This is the windiest I’ve ever had the boat down wind In, though. I was familiar with the waters, the destination, and areas I could anchor if a problem developed, albeit uncomfortably.
Trysail: it was too windy for double reefs safely. Jibing also become a problem. Sails with no boom are much easier. With a trysail I believe my speed might have been 6.5. Better handling. Better for towing kayak. My plan it to make a battened trysail that goes a foot above the spreader bars. It will be tied around the mast with line loops. The top foot will not be tied. The head board will be a foot long. The foot of the sail will be six feet long and will have a heavier batten. I will have to make some sheeting arrangements since the cabin top winches are in use. Here is a picture of the jib.
