It rolled up okay but the rotating gooseneck was not strong enough to support the boom. In the end it bent.
My invention did not work.
Nope - it was just for furling - no reefing.
Actually, your invention was fine. Your gooseneck/bearing just wasn't strong enough. That is easily fixed with the right machine shop and a wad of cash. Or, possibly, a grainger or McMaster shopping spree. Or a friend who does machine work for a hobby. I probably would have used a shaft and bushing, with the shaft serving as the connection to the mast; and the busing inserted several inches into the boom/drum. If I had to make it, I'd use a stainless shaft and bronze bushing. That way you could work in several different metals (aluminum, bronze, and stainless) to give you a future corrosion project...BOAT wrote: ↑Wed Apr 01, 2020 5:20 pm I had a rotating thingy on my topping lift that had a tang for the mainsheet block to attach to so that when you wanted to roll up the main you moved the mainsheet to the end of the boom where that tang thing was and started cranking to roll up the sail..
It rolled up okay but the rotating gooseneck was not strong enough to support the boom. In the end it bent.![]()
BOAT, are we related and don't know it with the same father?BOAT wrote: ↑Thu Apr 02, 2020 9:58 am I don't know how to weld and stuff. My dad made a furling boom way back in the 1970's that worked but it used the end of the boom and his boat had the mainsheet off the gunnels like a lot of other boats back in the day. His boat also had a backstay which is great for hanging stuff.
Rolling booms were common back in the day but fell out of favor as sails became more complicated with a lot mor geometry and battens and stuff. People wanted performance. As I recall they were never used as a way to reef - only as a main sail handling method. Very common.Russ wrote: ↑Thu Apr 02, 2020 11:38 amBOAT, are we related and don't know it with the same father?BOAT wrote: ↑Thu Apr 02, 2020 9:58 am I don't know how to weld and stuff. My dad made a furling boom way back in the 1970's that worked but it used the end of the boom and his boat had the mainsheet off the gunnels like a lot of other boats back in the day. His boat also had a backstay which is great for hanging stuff.
My dad also had a boat in the 70's with a roller reefing main. I seem to remember a crank handle or something. It was only for reefing. Nobody thought of rolling a main when not in use back then that I knew of. I remember seeing roller furling jibs and being in awe.
One day I was at the helm and my dad was hanking on the jib as we were coming out of Manasquan Inlet. When the tide is going out it often creates a big wave that crests just at the end. We weren't expecting it and one of those waves crashed over the bow and on top of him. He came back to the cockpit drenched and said: "Why didn't you warn me?" After that, he got a furling jib.
Cool! Got any pics?
Very cool!
