My OB is 2004 Mercury BF50 50EFI. It's a great fourstoke OB but it has a bid Achilles Heel. The standard Mercury electrical Regulator is underrated low quality junk and will blow up if I do the wrong thing .... I know because I have been through 3 of these now.
They will (sometime post event) self-destruct if ... they get even split second reverse polarity or a split second heavy load, like charging two low batteries turning through 1+2 on the switch.... Learning from my past experiences I now always turn through zero (never 1+2) on the switch.
But today I had the engine ticking over. I saw there were charging volts on battery 2 (so the regulator must be working) and while the engine was still running I turned the switch to zero and the engine stopped
I can't recall ever doing this in the past but I was kinda expecting it would keep running under it's own charging current? .... Could some confirm if this is normal for my OB?
I plan to upgrade the Regulator (when this one goes again) and I have already identified a much better (self protecting) alternative.
