Hi
I figure your somewhere out in the bush of sorts and havin had to make do in primitive conditions a time or two there is a trick if you are desperate enough that I used a couple of times on two-stroke racing heads that were warped beyond what the head gaskets could handle.
“Modern” marble counter tops are ground pretty flat.
You can check it with the edge of a good machinist’s square ruler several places in an overlapping asterisk pattern and a strong flash light.
Take the finest grade wet/dry Emory paper (400 grit or better for the finish, 200 grit to do the rough work) and using thinned contact cement apply it grit side up on to the cleaned marble surface. It helps to have a clean smooth cylindrical (check flatness with machinit’s ruler edge) marble pastry rolling pin to apply the Emory paper and flatten it out.
If you do it right you have a proto lapping table to manually level your warped head.
Emory surface should be roughly 2x your head contact surface area.
Wet the Emory and use a figure 8 motion to evenly level down the head contact area.
By figure 8 I mean take the head with one hand on either side and make a sideways 8 motion with the head about 1-1/2 times the length and width of the head seal contact surface area.
Don’t force it!
Just mainly let the weight of the head and the figure 8 motion do the work.
Keep the paper wet and periodically rinse the paper and head to clean away accumulating debris.
Occasionally rotate the head 180 degrees for an increment and continue the figure 8 pattern.
As your witness marks become uniform across the entire surface change to progressively finer grits using the same process.
Yes, the process is laborious and time consuming but if you’re in the middle of nowhere it’s a way to get the job done.
Alternatives surfaces are things like thick plate glass or a thick mirror on a solid smooth level surface.
The more stable the surface the better.
Another option is my preference which is to contact engine machine shops in a more developed area or country, talk to them and see if you can mail them the head. You’re not limited to what happens to be nearest to you locally.
Alternatively you might be able to find a new head via the internet and have it shipped to you.
Parts is parts. Keep an open positive mind and pleasantly surprise yourself!
(I’ve spent a career or two pleasantly surprised!
Hope this was of some help.
