Pardon me…..
DARN IT !!!FRIBBLE!!!
and
THANK YOU OPIE!!!
Now knowing that there have been multiple incidents of these ferrous (iron) keys having been provided with the steering wheels
We’re gonna EXAMINE & POSSIBLY HAVE TO pull our 20 year old steering system apart to see if this affects us BEFORE we end up in the same situation that Opie found themselves in.
THANK YOU OPIE!
Regardless of whether we have this condition or not, we owe you a beverage (or two) for being considerate enough to have pointed this potential out to us!
THANK YOU for the HEADS-UP!
Best Regards,
Over Easy
PS:
This reminds me of a technique my Dad taught me as a kid if the tiller snaps.
While our Macs have a steering helm the principle still applies.
The first is to take something like a boat hook pole and strap it to the side of one of the two rudders to make a make-shift tiller.
This works as I’ve tried it with and without the engine operational.
Just be gentle and not force it too much.
Something else is the standard drogue sea anchor steering method for when you might not only have lost steering but have lost rudders as well.
The technique requires a sea anchor and two lines
Needed:
1) sea anchor
2) 2 lines about 20 to 40 ft long each (adjust length depending on wind & sea & desired turn radius)
3) 2 stern end or midship cleats..
Tie one end of each line to the open end ring of the sea anchor.
Tie each of the other line ends the aft or midship cleats. One to port and one to starboard.
With the lines able to trail aft with out obstructions toss the sea anchor aft over the stern.
The lines will form a “V” behind the boat from the port side cleat to the sea anchor to the starboard cleat.
Pulling in on one of the lines to shorten it pulls the sea anchor to that side corner and by water drag turns the boat.
The more one pulls it in toward the one side corner of the boat the sharper the turn.
People have used both techniques to sail oceans.
HOPE THIS HELPS!
Over Easy
