A little background, we had purchased the boat after it had set in storage for a year in Florida heat. We changed out the water pump (kit), fuel pump, plug, oil, etc. Prior to changing all of that out, we fired up the motor. Despite the water ears on, the motor began smoking in a bad way. When we removed the waterpump, it was basically trashed and melted. Later, after we replaced the pump, we were not initially getting the telltale. We realized the water ears just weren't lined up correctly/not pushing enough water into the cavity. We aligned them vertically, then the telltale started working. With the telltale not working, I'm thinking that some of the original pump may have gotten stuck in the line so will likely need to trace the line to confirm whether it is clogged or not.
I'm writing to see if anyone else has had issues with the telltale not working and what solutions that they may have come up with.
Thanks!
