Straightening out a wavy, twisty furler foil/luff?
- LordElsinore
- Location: Salt Lake City, UT - "As You Wish" - Suzuki DF60A
Hi folks. The looooong grooved plastic piece that rotates around the headstay and allows the headsail to wrap around as part of the furler - I've seen it called a "headsail foil" and a "furler luff" though I'm not sure which is the correct name. Well, at any rate, I removed my headsail from it for the first time since I've owned the boat, which I'm guessing is also the first time it's been removed since it was originally assembled in 2012. Seeing it without the sail, it looks quite "wavy", a little twisted, but definitely not straight like I imagine it should be.
I was thinking about trying to straighten it out by hitting it with a heat gun and clamping it firmly between long boards or something for a while. Anybody tried something like this? Seems like it would be worth a shot. I know I can buy a new one from BWY for about $350 plus extra shipping, but I'd imagine this would be something that could work.
Any thoughts? Any suggestions of other ways to do this?
Mike
Mike
- Don T
Re: Straightening out a wavy, twisty furler foil/luff?
Hello,
Others will probably chime in BUT, I have not seen too much success noted when folks try to straighten the foil / luff. Mine usually straightens up after it's been up a while in the sun with tight forestay of course.
I recently ordered a new CDI furler from BWY. It came rolled up like a Danish Pastry. The instruction said roll it out in a warm area; it’s plastic, so it works.
Remove it from the boat; bring into to a heated area, roll it out. It will flatten out.
wakataka
Mine was pretty twisted up when I bought the boat. I wasn't sure it was salvageable, but I had nothing to lose so I laid it out on the patio, weighted it down with some bricks and a couple of long 2x6 boards, and left it in the 90 degree sun for about a week. The worst of the kinks straightened out but it was still far from straight. I was pleased to see that the remaining bends disappeared after it was installed on the fore-stay and the jib hoisted.
leefrankpierce
Go to CDI website and look at the installation instructions.
https://static1.squarespace.com/static/ ... manual.pdf
Says to put in a pipe, mast or something and let it warm up.
Page 5.
Page 5.
26X in Dallas Fort-Worth area Texas
Slip at Eagle Mountain Lake
- LordElsinore
Thanks for this info. Perhaps the most important part I got from that page was this:leefrankpierce wrote: ↑Tue Feb 08, 2022 7:23 am Go to CDI website and look at the installation instructions.
Page 5.
NEVER try to straighten the luff by using a hair dryer or by laying it on the ground and weighting it down along its length. These techniques do not work...
I guess I'll try putting it in a pipe in the sun like it suggests
- dlandersson
SmithDrewSmith
You don't happen to have a photo of your twisted foil before and after, do you? I have a pretty bad kink in mine, along with some other lesser bends and I'm just curious how bad mine is compared to yours. Mine was stored partially twisted around the life lines for the better part of 15 years.wakataka wrote: ↑Mon Feb 07, 2022 7:22 pm Mine was pretty twisted up when I bought the boat. I wasn't sure it was salvageable, but I had nothing to lose so I laid it out on the patio, weighted it down with some bricks and a couple of long 2x6 boards, and left it in the 90 degree sun for about a week. The worst of the kinks straightened out but it was still far from straight. I was pleased to see that the remaining bends disappeared after it was installed on the fore-stay and the jib hoisted.
