rsvpasap wrote: ↑Tue May 24, 2022 9:11 am I used 3M Scotch 5952 VBM double-sided tape at multiple attachment points on the bottom of both the microwave and airfryer. (It takes.a few hours to really securely set.) The freezer is held in place from behind with two heavy-duty bungee cords. I used Pettit Splash Zone to attach two small metal loops along the rear top edge of the freezer to which I attached the bungee hooks. Has all been in place for years with no problems (substantial heeling, major bouncing around in storms, the boat lives constantly in salt water).
Rearrange your passengers. Evenly distributing the load aboard your boat is the simplest way to help your boat run most efficiently when it's well trimmed (roughly parallel to its at-rest waterline, and not leaning too far to one side or the other).
Ray,NiceAft wrote: ↑Sun May 29, 2022 4:56 pm John,
I know your boat has not been out in awhile, but when you did have it under sail with all of the galley mods, how did it handle![]()
I've always wondered how our boats handled with uneven weight on the port side. I've seen many large galley mods reported here, but I don't recall any reports on how our boats handle this.
Many have made mods, including me, but some of the mods have been quite large and heavy; it's the effect those extensive galley mods have on sailing that I am interested in reading about. Does the boat list to port? Is there any compensation under power?
P.S.I just read this blurb in a BOATUS article on improving gas consumption, but it made me think of this thread. Think galley weight instead of passenger weight. You can’t rearrange the weight of the built in galley.
John,Highlander wrote: ↑Mon May 30, 2022 6:03 pm Ray ,
when i do these kinda Mods I,m very weight concus as to total displacement of weight distribution, most on here use heavy plywood or other heavy materials. All my cabinetry I use alum angle as frame work for strength & light laminated flooring material which is sealed front & back so only have to reseal cut edges & I usually use matt black plastic paint for that as it gives off a 3 D effect visually !
so my hutch & over head cabinets & window frames & bulkhead wood work is all laminated flooring so is approx 75to 85% lighter, that these other mods made with heavier materials why guy's don't take that into consideration I,ll never know![]()
I considered all the futurer mods I would want to do over the yrs & realized I had to go with a different mode so I went with the modular concept easy assembly lightweight modular systems that can b easily removed & updated or totally replaced with a newer & better concept or just removed period as needs & Idea,s can change over time & thats how how they build ships these days , Navy , cruise & tankers & freighters, so I guess I,m either ahead of the times or just keepin up with them![]()
so no issue,s& some storage is designed to b re distributed as is necessary depending on crew size or other factors like food distribution & beer
, Scotch get,s first priority
J![]()
window frames each of the top window frames snap together to make one continuous frame for both top windows & same for the lower frames
