Hi All!
Speaking of lifting insitu engines….
I’ve used several different approaches for lifting an engine already on a transom.
My 1st preference is to use a self supporting engine crane.
Stable and also allows for movement and storage.
While this might be my preference it might be a bit more than needed in this situation where one only needs to move within the slot range of the engine transom bracket. So if your existing mount is set up through the mount slots and there is slot space to allow the engine to move up.
My second choice is to use the boat AND the trailer.
First with the boat secured to the trailer one lowers the nose of the trailer with the tongue Jack.
Then appropriately and with stable cribbing placed under the engine Skeg so the the cribbing and Skeg is just in contact.
Then loosen the engine bracket mount bolts through the transom so are free.
At that point one raises the trailer tongue with the Jack while a second person watches the stern of the boat drops while the engine stays at the same height on the cribbing until the bolts move down the slots of the engine bracket.
Once your at the bottom of the slots stop and measure the vertical gap that has formed between the top of the transom and the inside of the engine bracket surface. Cut a block of marine grade teak or other appropriate material (such as fiberglass block/plate or aluminum) that fits the space from one side of the engine mount to the other side.
After the spacer is in place tighten the transom mount bolts.
My third choice is if the engine needs to be raised higher than the engine bracket slots allow.
This get more complicated and difficult.
I’d go back to my first choice and remove the engine entirely to drill new mount bolt holes and appropriately epoxy fiberglass seal all the old holes.
Then remount the engine, insert bolts and tighten after inserting an appropriate shim in the gap between the top of the transom and the underside of the engine bracket.
I’d be remiss if I didn’t mention the potential to use a scissor Jack or hydraulic Jack but that approach could be unstable.
It’s not worth anyone getting hurt if something shifts or moves inadvertently…
Hope this helps some…
Best Regards
Over Easy
