26X "Mac Slap"
Re: 26X "Mac Slap"
:D :D :D
NiceAft wrote: Thu Feb 08, 2024 4:08 pm Rich,
You just emerge from the shadows, deliver your wisdom, and then melt away until the nex time you’re needed.
It’s a bit long, but you get the idea
pitchpolehobie
Re: 26X "Mac Slap"
Post by pitchpolehobie »
Found this on bwyachts for the 26c. Similar to what id try for with the rubber spacers.
https://cdn4.volusion.store/reeua-fzzpa ... -1C3-2.jpg
2002 MacGregor 26X: Remedium
Tohatsu 25HP
pitchpolehobie
Re: 26X "Mac Slap"
Dropped my CB for the first time. I put a camping mat down and let my CB line out about 4 inches. After that i tapped the CB hanger screw thru the hull and it gently landed. CB is in excellent shape w original gelcoat. The line was severely frayed and cut when my razor just touched it. The hanger had some corrosion I suspect from the PO however I suspect it had at least the CB pivot pin replaced - looks like electrolysis afaik. Pics of CB hanger corrosion to follow. Its an 02 and i suspect was in saltwater til 09-10.
Note I had no issues with it but had never given it an indepth inspection. I dont think the hanger is near structural failure but I have one to replace it and will along w the pin.
Tohatsu 25HP
Be Free
Re: 26X "Mac Slap"
Post by Be Free »
pitchpolehobie wrote: Thu Feb 08, 2024 3:29 am So doing some extra thinking...which is dangerous and expensive for me. I figured maybe insert something like this to help with friction between the rubber and the centerboard :macx: . We used these at the base of rotating mast on a hobie 16.
https://www.ebay.com/itm/166330670008
Prob worth a trip to the hardware store to find something similar and maybe less $$$
Whenever one of my kids started a conversation with, "Dad, I was just thinking..." I'd reply with "Dangerous pastime; best left to professionals". :D
Bill
2001 26X Simple Interest
Honda BF40D
March
Re: 26X "Mac Slap"
Post by March »
There was an older thread (which I could no longer find) about putting a tight ball-bearing ring around the centerboard's axle, which will allow up-and-down movement freely, but not so much laterally so it wouldn't bang against the walls of the boot. I'd been considering it in the past, but never got around it.
I did try inserting some "cushions" in the boot itself, but had problems with the centerboard going down freely and easily, so I removed them--and learned to live with the consequences. But a better solution would be totally welcome!
pitchpolehobie
Re: 26X "Mac Slap"
My CB is in good shape and has the original gelcoat. The rest of my hull that touches water has rustoleum copper antifouling. Is there a strong reason for or against putting antifouling on the CB (I guess it made this far without)?
Tohatsu 25HP
Gordo
Re: 26X "Mac Slap"
Post by Gordo »
pitchpolehobie wrote: Tue Feb 06, 2024 7:19 pm I also have the bwyachts CB dyneema line. What knot have you used to stay snug and not slip but also fit in the CB notch?
I haven't replaced mine yet, but when I do this spring it will be with Dynema as well. Knots don't hold well in this slippery line, and, as mentioned, it doesn't cleat well either! I use Amsteel Blue (https://duckworks.com/amsteel-blue-12-s ... ctra-line/) for a lot of rigging, and I REALLY enjoy it.
The key is learning the Locked Brummel eye splice ( Once that simple splice is in your toolbox, the world is your oyster! There are variations, including "one end fixed" or when you can't pull through the other end of the line (
Thus I would splice the line directly to the centerboard, pull it through to topside, and then form another splice with a thimble. To this I would tie a length of non-stretch line (https://duckworks.com/marlow-excel-racing-line/) which will the hold really well in your cleat.
X for the Comfort!
Sailing the Texas Coast and beyond
2000 Mac26X, original Tohatsu 50HP
