Russ, with that picture you posted I have some questions
You've got an
right? There are some things there that I've not seen on an
before.
Going from right to left, I assume that first line is your furling jib/genoa. Looks like the next line over is a means to raise and lower that - fancy that it goes over the top of the mast and back down the other side. Does that kind of arrangement have a name?
Then you've got two other 'lines' that look like steel cable after that. Is one of those a backstay? Do you have a backstay on your
What I don't see is your main halyard, a topping lift, etc. 'splain yourself, Sir!
Also, you have tacking tabs on your Windex....but your
has a rotating mast. Are you able to make use of them?
Thanks for tolerating my curiosity
