Hey Guys,
Again, asking questions about the 26M.
The Dagger Board enclosure or the structure that holds the board in place, what is it called in this forum?
Has anyone exposed it from the inside of the cabin and what do you think it is made of from hull bottom to the deck?
Thanks, Ed
26M Dagger Board Enclosure
The Islander
- LordElsinore
- Location: Salt Lake City, UT - "As You Wish" - Suzuki DF60A
Re: 26M Dagger Board Enclosure
That cavity is called the daggerboard trunk. I'm pretty sure it's just made of fiberglass like pretty much everything else on the boat. But, I haven't exposed mine or cut into it or anything to know for sure.
- Ixneigh
It’s fiberglass. I removed the carpet from part of it.
Ix
Ix
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
2011 M, white
Tohatsu 20
South Fl.
Yep. Fiberglass. It is probably also structural to hold the deck and mast from compressing.
On the 26M it is solidly attached to 300 pounds of resin at the base.
