I placed this scrap of 1 inch thick plywood sheet on the front of the bow pulpit, traced the location of the bars underneath onto it with a sharpie, drilled some holes and used some 1 1/8" stainless u-bolts to secure it down. Cut out a curve with a jigsaw to prevent the jib furler from rubbing on it, and used a throwable cushion on top.
She liked it a lot! We only used it in light winds and low heel and never when motoring. In the future I plan to sand the rough edges, stain it and coat it with epoxy, and maybe cut a slot in it so that the mast base can pass through it when attaching for trailering. For now, I just remove it pretty easily
