I'll make it even easier. BWY will ship you a PRE-DRILLED mast with all the holes you need already where they need to be. You may have to drill 3 new holes for the VHF antenna.OverEasy wrote: ↑Mon Sep 09, 2024 7:57 pm You have all the existing hardware to give you any dimensions you need … this is all pretty simple and straight forward.
BWY can and will ship to you any of the particular parts needed.
A Nicro crimp hand press isn’t a significant cost for the cable stays AND you already have the existing cables to replicate from.
Heck, there are lots of cable companies that will be happy to provide them as part of the cable purchase.
If the cable is eyed to a fitting they can do that too!!!
They will ship you new rigging with all the stays PRE-SIZED to exact lengths and ready to attach.
No drilling needed. No crimping. No measuring.
They will also send you new spreaders PRE-CUT to exact length and drilled ready to install.
All you need to do is remove the hardware, reinstall it on the new mast and boom, you are back sailing.
The wiring....should all be reusable unless you want to redo it while you are at it.
All this is easier than building a Lego set.
