Be Free wrote: ↑Tue Sep 17, 2024 8:00 am
Do you have any wrinkles in your luff now? If it's already tight then a Cunningham will not have much effect.
Not a lot. I can usually get the halyard al the the way up.
Be Free wrote: ↑Tue Sep 17, 2024 8:00 amYou should not have to make any extraordinary adjustments to the main (like allowing it to flog) to safely and comfortably sail in a 10 knot wind. That is pretty much the "sweet spot" for an X.
A 10 knot wind will invariably cause SeaSaw to round up on a close reach or close haul. (Yes, I have my ballast in and blades down.) Often, I can luff it a little and it's OK, but sometimes I have no choice but to flog it or I just round up. This can happen even when reefed. OK< thi might be more of a 15+ knot apparent wind. I do fly a 150 genoa, though if it's really blowing I'll furl that to 50% or 30%.
It's also possible I am dreadful at knowing my wind speeds. It's my estimation that whitecaps start to appear above 9 knots, so if I see enough of them, I assume I'm in a 10-knot wind. (And, of course, 10-knot true wind will be a 14-15 knot apparent wind on a close haul).
Next to my depth-sounder, an accurate wind speed indicator is my next most desired piece of nav equipment. I have never had much luck with hand-held wind-meters. I wonder if there is a less expensive wind-meter option. Something that I could mount on the bimini, say. (Maybe I should just get a windsock...)
Are there other issues with the main that need to be addressed?
Quite possibly. I just bought a new main sail. It's used but still in great condition. It was still very 'crinkly'. If there's any 'issues' with it, they be at the bitter end of the main sheet, operating the steering wheel.
I do wonder if my skillset has gaps. I've been sailing for at least 15 years, and I did take Beginner and Intermediate Sailing courses (on a Beneteau 38) and raced on 32' cruisers for two years. But these"real" sailboats aren't the best at learning what works on a Mac. (For example, when you point a sailboat on a heading, it tends to
stay pointing on that heading longer than three seconds ...
