The Admiral Wants Heat
Re: The Admiral Wants Heat
Jimmyt wrote: Mon Jan 06, 2025 7:29 pm Progress is slow. Jury duty this week. Also, I’m slow-rolling on purpose to let the design marinate in my head. I’m hoping to only build it once.:wink:
Smart to let it "marinate". I find time is my best editor.
Looks good so far. Can't wait to see the complete project.
Post by Jimmyt »
A bit of progress. Crawling toward a test fit on the hatch opening to see if I can see over/around it from the helm.
I’ve got some router work and sanding/shaping to do before it’s ready for finishing.
Also, I’ve got to work out the tank mount. I may have to source another tank before I’m happy with the look.
Very interesting. So are you keeping the fuel as part of the kit? It's a diesel heater correct?
Post by Jimmyt »
Yes. The plan is to just drop it on the hatch and plug in the power.
Post by Jimmyt »
Well, finally got it together enough to toss it on the boat. I leveled the waterline and took measurements on where I need to position the upper section. The aft end has to go down 1-1/4” with the forward supports basically staying at the current height. Visibility from the helm is minimally impacted - much less than I was expecting after seeing it from the side.
The only “gotcha” is, someone moved the anchor hatch about 4” aft while I wasn’t looking! I had to laugh at myself for that one. I should know better. So, anybody that wants to give me a dig; have at it - I’ve got it coming.
Anyway, it looks like it’s going to be fine - albeit a bit different looking. Won’t matter, though. I’ll be the only one on the water when it’s cold (besides the fishermen - who don’t really care).
Wow, that looks really cool installed. Nice work.
Anchor hatch... eh...I'm assuming you can move the heater top back a bit for that.
Post by Jimmyt »
Russ wrote: Tue Jan 14, 2025 2:50 pm Anchor hatch... eh...I'm assuming you can move the heater top back a bit for that.
Nope. Going to have to trim a little off of the front. Not too bad of a hit. Good practice.
Jimmyt wrote: Tue Jan 14, 2025 5:46 pm
Well, I wish I could I've never done something like that. :?
Still looks cool. I like the shape. So how are you going to finish it? Put some racing stripes to match the Mac raccoon stripes.
Post by Jimmyt »
Current plan is penetrating epoxy, some fiberglass, then white and black paint to match the boat.
Post by Jimmyt »
Well, the changes are made after the initial test fit. Gave it a nose job (removed a couple of inches), to clear the anchor locker and adjusted the heater deck angle to be parallel to the water line.
Thanks to Russ for putting the idea in my head to slide the machine deck back. I couldn’t move it much as I already cut the air transfer opening, but was able to cheat 1/2” more by sliding it aft. That allowed me to reuse my original nose piece, after slight modification.
Now, on to the inside piece and figuring out how to lock it in place.
Post by Jimmyt »
Been working on it quite a bit, but not much visible progress. I’ve completed the skeleton of the interior piece. It serves as the clamping mechanism to hold the top part in the hatch opening, and will trim out the interior.
The skeleton will have fleece stretched over it and then, the fleece will be saturated with polyester resin. After it hardens, I’ll skim it with filler and paint it.
The diffuser is mounted to the upper (outside) part, and I’m currently thinking of using the slots on either side for return air.
That's looking nice and professional. Reminds me of those AC units on top of RVs.
I have a feeling you are going to be nice and toasty in there.
Post by Jimmyt »
Russ wrote: Tue Jan 21, 2025 5:49 am Reminds me of those AC units on top of RVs.
Thanks for the kind words, Russ.
I wanted to keep the fuel tank, pump, and fuel tubing out of the boat. So, the RV rooftop unit was the inspiration for this project.
Now, if you would please get your weather to come home, I’d appreciate it! I have stuff to do and Mobile AL is not equipped to handle this weather.
Cool. :D
Jimmy, you have more snow than we do. I saw snow on the beach in the Gulf in Destin Florida. Crazy. New Orleans with snow. Nuts.
Woke up yesterday to -15f
Today a heat wave of 30f
So maybe some relief is coming.
