I am sure you can purchase a mast hound locally. I found this one in Europe. Kurz has sourced one in Europe.
https://nacrasailing.com/product/mast-hound
I installed a second mast hound ABOVE the forestay. This is necessary so it does not interfere with the head sail.
I have a simple line from the new mast hound above the forestay down to the bow pulpit where I tie it off with a simple knot.
Once you replace your bent spreaders with new straight tube, your boat will be strong and safe. You may be able to see the angle the spreaders are raked back.
click to enlarge
