Hi Ixneigh and Rsvpasap!
I missed this earlier….
The bunk block supports you came up with shouldn’t be a problem Ixneigh but if you’re gonna be doing this in a regular basis might I suggest that you take a bit of time and make a more conformal one?
I’m concerned that the bottle jack and wooden squares you are using could slip or shift catastrophically and result in potential injury or harm to you or your boat. Solely relying upon friction at an unstabilized single point loading column like a bottle Jack is precarious at best. Just a slight shift of the boat could have that suddenly popping free…. Just wouldn’t want you to get hurt.
I regularly clean and repaint the bottom and made up a stand out of pressure treated lumber that rests on the ground at the stern. (Photos below) It incorporates multiple 2x6 shims so I can adjust the height higher if needed for additional clearance such as to better fit the pressure washer wand and paint rollers. As the stand is at the stern I can easily complete that portion when I lower the boat back onto the trailer bunks.
To raise/lower the boat I use the teeter totter method using the tongue Jack, the stand and shim boards on the bunks.
First I securely chock the wheels on both sides front and rear so there is no chance for the trailer to roll.
I also use a capture pad block for the trailer Jack wheel so it can’t move in any direction.
The last thing I’d want is for the boat or trailer to wander about while I’m under it! (I might have been able to bench press the boat in my younger days but I’m not that young any more
Once I’m sure that everything is secure I lower the tongue Jack all the way down which raises the stern. I sized the basic stand to just fit about a foot in under the stern at this point when on level ground. Please Note that the stand operates in compression, can’t spread apart and has a broad stable base.
Then I raise the tongue Jack to lift the bow up to the highest it can go. I place 2x6 shims on the now exposed trailer bunks to pretty much fill the gap (remember the stern is now resting on the ground stand).
Then I lower the trailer Jack all the way down again which again raises the stern up off the ground stand. I place additional 2x6 shims to fill the gap between the ground stand and the stern bottom. I repeat the process until at the clearance height desired when the boat is resting on the stern stand and bow.
This provides a good stable 3+ point supporting structure to safely work underneath the boat.
To lower the boat back onto the trailer I simply reverse the process.
This process always provides a good stable reliable support for the boat. This minimizes any chance or opportunities for things to inadvertently slip or shift position which could result in harm or injury to me or the boat.
The adjustable Jack stands like Rsvpasap pictured look to be physically capable of supporting the weight of the boat like the stands utilized in boat yards. But in a proper boat yard there are securement chains attached to the stands so that there is no possibility of the stand bases moving apart. Often there are additional chains provided that cross from the top portion of one stand to the base of the stand opposite to prohibit the top of the stand from possibly tilting outward. The narrower the base of the stand the higher the probability of the stand potentially tilting outwards due to the curvature of the hull. Additionally, Most boat yard stands are designed with wide bases, fixed attached pads and a tilt to one side which is faced toward the boat center. This is done to improve stability. Automotive type stands are straight up/down and are designed to only interface with a vehicles frame’s flat surfaces only in a purely vertical loading. Not angled loads which can potentially result in tipping or shifting laterally. Boards pinched on single points of contact such as the top pad of an automotive Jack stand has the potential to slip due to the lateral forces of a curved hull and/or cause the stand to tilt. Please be careful.
In my careers I’ve had the unfortunate opportunity to have witnessed many accidents and damage sites which could have been avoidable with proper planning. I just want everyone to have a long and healthy life especially if a potential incident could be avoided.
Best Regards,
Over Easy
