The plan is to go to one 80Ah lead acid starting battery and a 300Ah LiFePO4 battery. It's going to be a lot of work. The plan is:
*Starter battery linked directly to motor through an unfused wire with a battery on/off switch rated for motor start.
*Starter battery linked to a 1/2/Off switch (not both) through a 125A terminal fuse so that the starter battery COULD power house loads if for some reason that was critical.
*Starter battery linked through a 40A inline fuse to a bluetooth-enabled 50A DC-DC charger with solar MPPT, set to 30A charging via onboard software.
*DC to DC linked to 300Ah house battery through a 40A inline fuse
*New 100W solar panel from BougeRV that's supposed to do very well in partial shading. The solar feeds directly to the DC to DC charger, which then decides which battery should get the solar juice (I think it prioritizes the starter battery).
*Negative terminal of the 300Ah battery linked directly to a bluetooth-enabled Shunt300, which monitors both the starter and the house battery.
*300A fuse from house battery to 1/2/off switch to power house loads.
*6A shore-power charger for starter battery
*10A shore-power charger for house battery (yeah that's small but I already own it).
AI gives the wiring diagram the green light, and suggests to consider adding 1A fuses to the dashed voltage-sensing lines. Given the number of mistakes AI made in developing the plan, I sure would appreciate some human feedback
PS I seriously don't know how I'm going to physically add the motor on/off switch: IIRC the dealer used extremely heavy gauge wire to minimize voltage drop to the 90HP, and I don't know if my crimper will do that wire size. I forget what it was but I wanna say it was around 0 guage: all I actually remember is that 20' of it cost me like 400.
