Hi Chip,Chip Hindes wrote:I would be pretty surprised if the Honda was that much better at WOT, especially since it's carbureted.I believe a Honda 4 stroke 50 is less than 4 gph at WOT
I made a long and fast motoring trip last year where I did 80 miles in about 5.5 hours of near WOT speed (I always tend to back off a bit from full throttle for a normal cruise speed) and used about 21 gallons of gas. This would compute to around 14.5 mph average speed with a fuel consumption rate of about 3.8 gallons per hour. As you may recall, I have the 2000 Merc BF 50 which is a carbureted 4-stroke. Obviously, on a long trip like that I wasn't always going exactly the same speed so there is some deviation to the average. Range of speeds was usually between 12.5 to 16.5....and, my hull did have some growth on it at the time so I'm wondering if I could have done even better with a clean bottom.
Dimitri
