Thanks in anticipation
Towing Points on an M
I intend to tow a water toy for the kids this year. Where should I attach tow lines on the boat?
- Balu
I pull my kids on a tube with the line connected to the rear mooring cleats via a line and pulley available from shops who sell ski's etc. Whether this is the right place or not I have not had problems as the height of the stern keeps the line clear of the motor.The cleat fixings are strong enough.
I leave the pulley on the outside of the push-pit so that it moves freely from side to side.
- baldbaby2000
- kmclemore
I use the rear cleats, though you're right that the rudders tend to get in the way. Presently I just tie to one cleat and I've had no problems, but I've considered making up a Y-yoke, where I'd have a loose loop running from cleat to cleat, then have a pully running in that loop and tie a line to that, leading to the pull-toy.
- Dimitri-2000X-Tampa
That's how I do it on my X. I make a bridle with about a 10-15 foot long piece of line tied between the two stern cleats. I tie a small (floating) fender into the middle of the bridle so that it won't sink down to get in the prop. Then I attach the tow rope near the fender also. The fender comes out of the water at speed.
All my tow ropes and bridles are made of that polypropylene (sp?). The whole rope floats...
With my setup, I use those purpose built bridles, made for ski boats. They usually have some additional flaotation built in...
I have one bridle that the tow rope connects to a pulley that rides the bridle. This was a bad choice, as it is constantly changing the load from the tube... I can't keep the boat straight with it...
- Captain Steve
DLT, that sounds a little like the Dinghy Tow. (Previous thread)DLT wrote:Anyone ever use any kind of rigid towing bridle?
I'd like to pull my canoe behind my Mac, but I don't want it running into the rear...
