Ok fine...lest my comments be misinterpreted, you should never foolishly exceed your own skill levels, however a boat is a boat and there is not much difference in operation between a 26 footer and a 35 footer....forward, reverse, port, starboard...and your diesel will have a preheat button (which you hold down for 10 or 20 seconds prior to starting) but other than that, I think its easier to drive than a Mac without all those boards. Sails go up the same way but with bigger winches (you don't need to know how to use the macerator or the water heater yet). Its not quite the same as going from a single engine Cessna to a pressurized jet airplane in terms of operational complexity. If you had the skills (and local knowledge) to take your Mac out the Gate, you could probably handle the bigger boat just as well, in fact, it should be a much nicer ride in the bigger heavier boat...easier, not harder.I'm sure you will be better off with a competent delivery pilot!
But it certainly never hurts to have some more experience on board. Instead of paying someone 800 bucks though, maybe make some friends on a Pearson or SF Bay web site and find someone who will make the trip with you for some food and beer instead.
All comments made for entertainment value only and should not be taken as advice
