Welcome & congrats on your new boat!
(and with apology to the forum, I'd like to use the word "planing.")
I think you have some good advice above. But since there's some debate about the Mac's "true hull speed," your setup can make a valuable contribution, IMO. I'm guessing that your outboard might get up to 9 or 10 mph, assuming you are alone, without planing. It would be interesting to see if it can accomplish that same speed with 4 persons aboard - but I doubt it.
(But - on edit - as Slamjammer says just below, I believe you'll easily be able to empty the ballast tank.)
The "hull speed" of the 26X, according to the traditional formula (dating to 1600s) is about 6 knots, or 7 mph. According to a modern adaptation though, a "modified formula" shows hull speed of the 26X should be 8 knots (about 9 mph). This is for a semi-planing hull, and it's variable depending upon load. Since your 18 hp certainly won't
plane the hull, it should just manage to push your Mac to its "true hullspeed." (Simply my observation and guess, I feel the 26X actually begins planing at about 12 mph. But as inferred above, it takes beaucoup horses to increase the hull's speed from 9 mph up to 12 mph.)
But, if your boat can reach 9 mph, by GPS, in flat water, no currents, with only one person aboard, then I believe it will be pretty good evidence that this boat's "non-planing hull speed" exceeds 6 knots. That determination will help to index the theoretical maximum upwind sailing speed of a 26X. (Downwind sailing can more easily exceed hull speed.)
Assuming that you care to do a little testing, I would surely look forward to reading about your results. You have a terrific boat ... Congratulations!
