One interesting thing when I was flushing today. Out one of the little exhaust passage ways, what looked to be a few small pieces of magnetic tape (like what you would pull out of a cassette tape) was stuck in the hole so I pulled them out...the tape was rather brittle. To come out the exhaust hole means the foreign matter would have had to go all the way through the motor's cooling system. Anyway, does not seem to be running any different than the last time I did this (after I got the water flow back up) so I have a lot of good spare water pump parts now.
I have a boat mechanic who lives in the neighborhood. I got his attention the other day and he seems to think that my tell tale hole is letting out too much water pressure and that it should be plugged when the motor is running. That's funny...I've used the motor almost 3 years with it pee-ing happily out that hole. Anyone else have a 2000 (or older) Merc BigFoot 50 which has a covered up p hole (where the hose threads are)?
Anyway, he sold me a one way valve that closes off the flow. I had actually argued this point with the guy at the Merc shop last week. The fact that if the P hole starts getting too large (from being reamed and broken off, etc.) whether it might start starving the top cylinder for cooling water. The Merc guy shrugged it off as nonsense. Funny thing is that today, after I got everything back together, I ran with the muffs for about a half an hour and experimented with a meat thermometer. With the p-hole water blocked off, the area near cylinder 1 (top) on the head was a good 15 degrees cooler, same with the area around the overheat sensor on the water jacket. It was pretty consistent. Open the p hole and you can see the pressure slowly drop in the stream. When the pressure drops, the top cylinder starts getting hotter. Plug the p hole up and the temp starts dropping immediately. I did it back and forth about 3 times to make sure that it was a correct trend. The exhaust water stays about the same temp...around 97 degrees. But if you cover the p hole, it goes up to about 101 for several seconds and then cools back down to 97..as if it had just carried the extra heat away from the top cylinder which was getting water starved. The overheat sensor is near the top cylinder of course.
I asked the neighbor mechanic..why have I been able to run fine for almost 3 years? He seems to think I was just on the verge of overheating but staying just under the warning horn. This explanation makes me a bit skeptical though.
Anyway, I'll try to put it back in the water this week to test under load. Obviously, running with the muffs is no load and even revving it up a bit, I could not get the overheat alarm to go off. So whats the deal, anyone think I could do any damage by blocking the p hole off? About the only thing I can think of is if there might be too much pressure build up at higher rpms. I'll take my new knowledge (and my one way valve) out in the bay and see what happens. Whether I can make it overheat anymore with the regular p stream (which is about as much as the 1/4 npt size water dispensor stream from my fridge's exterior ice and water dispensor) and if so, whether stopping off the p-stream makes the overheat warning go off.
This is strange stuff but the plumbing is pretty straight forward really. Another interesting thing is that there is an exhaust bypass hole right under the p hole. With the p hole open, no water ever comes out of that. But with the p hole blocked off, water spits out at times. Like before the thermostat has opened, it seemed to spit out quite a bit but after the engine heated up more, no more came out of there (presumably because the thermostat is now open). I'll have to find someone else with the same motor and see what it looks like. If my p-stream has gotten a bit too wide, then it could be like a pressure cooker without the weight on top. The weight is just enough to keep the pressure right. Pressure definitely drops when I unplug the hole, you can see the pee distance decreasing slowly as the water must leave the top cylinder but still have enough pressure to cool the other 2-3 lower cylinders. Anyone ever make similar observations?
