Not sure if I can picture it in my mind..sounds overly complicated...why mount a swivel pully on the mast? The setup on our boat goes from the mast top to the base plate pulley, to a second cheek block on top of the daggerboard block, back to the cockpit with a linelock. (see pics above). There is zero issue with the mast swinging.Terry wrote:How about a swivel pully without the cam cleat a foot up the mast, then another one at the base plate to direct the line out to the daggerboard pully then back along the hatch slide to a clutch or cleat at the cockpit? That may work better with a dodger.
Here is what I used for inspiration (I used a slightly modified version of the first setup):
Harken halyard handling page
Paul
