Lead my lines aft this winter and bought a chute scoop.
All in the interest of making life easier. Well the first weekend we sailed with these mods and the verdict isnt in yet.
As for lines aft I can see where this will make life better. Maybe eventually cure SARS or bird flu. Right now Im unfamiliar with the locations and stowage so it didnt work well. Next tme out I will have hooks on the mid rail to stow the tailings when not in use. What a mess the cockpit was!! The main halyard alone drops 28 extra feet of line into the cockpit!!.
Also had a very difficult time deciding which line should be over and which went under, this shouldnt be a prob after a week or two.
Now for the chutescoop. Hmmmmmmmm......... I will keep you all posted. I shouldve practiced at the dock. Its not as easy to use as the video shows. Im sure I will get it wired. Also lead the newly dedicated spinnaker sheets around the front of the pulpit and haveing always inside jibed or tacked I was unprepared for the spin sheet getting caught under the anchor holder when we did our first outside jibe. Quick rush forward to clear the jamb and all was ok. Fortunatly we were using it in very light air!! For dousing it worked awsome ( I was better at launching it from a bag)
Stay tuned to this channel, there may be a hull of a sale on chutescoops before the end of the season. (or not if I get it wired)
Another difficulty is the dedicated spinnaker halyard. At first I was under the impression that I had overloaded the mast with lines. I started getting used to it by the end of the 2nd day but sailor be warned... it may sound cool before you do it but plan your additions carefully.
Sometimes less is more!!
