Bad rep? Do any boat manufacturers still use chopper guns?Most of our competitors use "chopper guns" to build their boats. These are devices for spraying a mixture of resin and very short strands of fiberglass. We don't use them, even though they reduce cost. They do not, in our opinion, give adequate impact strength or controllable hull and deck thickness. They result in heavy laminates with low fiberglass to resin ratios, accounting for much of the excess weight found in many competitors boats. Light weight is the key to easy trailering and to high performance.
Is
BS?Most of our competitors use "chopper guns" to build their boats.
How strong is Mac fiberglass? The sides sure seem to bend in and bounce back on impact. Why is this? Good or bad?
