So here's my question...do you think it could be glued back together? It's a very clean break...if so, what glue do you suggest? Otherwise it's $260 CDN for a new part
Any advice is appreciated!
Thanks folks!
CDI Flexible Furler
Limited 6 Year Warranty
The Flexible Furler is warranted to remain functional for 6 years from date of purchase. You must be the original purchaser of the unit. If, during this period, any part becomes non-functional, CDI will repair or replace it, free of charge, except for freight.
The Flexible Furler warranty covers:
At Sea: All hazards at sea, including winching against obstructions, unseamanlike use, and dismastings. This warranty remains in force for charter and other commercial operations. No maintenance is required to keep the warranty in force.
The Flexible Furler warranty does not cover:
At Sea: Shipwreck, collision and acts of God. The warranty is void if the mast is not fixed in place vertically at all times while the boat is in the water. Tipping the mast forward to pass under bridges, power lines or other low clearance obstructions voids the warranty.
On Trailers: Collision; being dragged on the ground; improper stowage resulting in kinks, bends and twists; and damage due to the luff not being supported over its entire length. (See trailering instructions.)
Storage: Any damage caused by improper storage or handling when not at sea. Luffs must be stored flat and straight, or warranty is void. Kinks, twists, bends and breakage due to the luff not being stored flat and straight are not covered. Coiling or twisting the luff either to remove kinks and bends, or for transport and storage in other than a flat and straight condition voids the warranty.
