Davis Masthead Light
i mounted this which came with two bulbs. a low draw, low output and a high output. I have the larger bulb installed.
"Mega-Light Masthead consumes just 0.110 amps (approximately 1/10th amp). It features a light sensor that automatically switches on at dusk and off at dawn. The dual-function Fresnel lens projects light for up to two nautical miles (3.7km).
Mega-Light Masthead comes mounted to a stainless bracket for easy installation to a masthead, interior wall or bulkhead. Comes with 12" (30 cm) lead wire. On-off switch and fuse holder for hard-wire installation not included.
Comes with two easy-to-change light bulbs. One bayonet-type bulb draws just 0.110 amps and can be seen for up to two nautical miles (3.7 km). The other bayonet bulb draws 0.320 amps (approximately 3/10th amps) and is more than twice as bright. Includes a standard lighter plug and 15 foot (4.5 m) cord with easy hanger."
isn't this one USCG approved as an anchor light?
Bob T.
"DaBob"
'02X w/ '04 90-TLDI & '06 2.5-Suzuki
