You must be younger than me as I have never been convinced that we should have changed to metric.
We now have a system where we have to use both and that is not likely to change, very little was metric prior to changeover and we are still paying the price of trying to match existing gear.
There was as little reason to change to metric as there was to change to international wiring codes (european).
We are far more closely aligned to England and America than any european country.
I have no problem with French as I am of part French descent but they can stick their metrics.
Back to the subject of Clorine (as you seem so knowledgeable on the subject), would there in your opinion be any cleansing effect by filling tanks with treated tap water? or would that not give you the "shock effect".
Also what would in your opinion be the required micron rating of a filter to eliminate harmful bugs, impurities if that is possible.
