Posts: 10421 Joined: Fri Jun 11, 2004 5:59 pm
Post
by Catigale » Tue Jul 31, 2007 4:36 am
Ive got the wheel/drum off my trailer and am seeing a circumferential pattern on the inner bearing race, inner race that sits tight on the axle hub.
Not sure if I should worry about this, since it normally just stays still while the bearing is spinning...anyone care to comment
Couple of pictures here
On edit: fixed bearing reference
Rich Walton
Posts: 79 Joined: Mon Jan 05, 2004 1:05 pm
Post
by Rich Walton » Tue Jul 31, 2007 10:32 am
I think you are looking at the surface that the seal rides on, the wear is normal, if it is bad you need to get a sleeve on it.
Post
by Catigale » Tue Jul 31, 2007 10:55 am
Thanks Rich - the bearing runs smooth and quiet, so it sure feels ok.
Posts: 6295 Joined: Sun Feb 08, 2004 9:24 am
Post
by kmclemore » Tue Jul 31, 2007 1:15 pm
Yep, that rearmost shiny flange is indeed the seal surface. When I get one like that - all shiny - I will sometimes take a strip of emery cloth and just gently scuff it up a little so the next seal beds in nicely, but it's not critical.
Post
by Catigale » Tue Jul 31, 2007 2:06 pm
No grease in the brakes, so Im putting back together as is
Thanks for inputs everyone...
