Page 2 of 2
Re: High speed motoring change
Posted: Tue Sep 03, 2024 12:02 pm
by Be Free
Great news! I glad you found the problem.
Did you try to move the prop by hand? If so, did it slip? Just checking for future diagnosis.
Posted: Wed Sep 04, 2024 8:03 am
by Macsailing
I did try to move the prop by hand...but i couldnt tell whether the prop was spinning or if i was turning the motor over.
As far as ballast, i do fill the ballast when it gets rough.
Thanks again.
Posted: Mon Sep 09, 2024 4:33 pm
by Carioca
keep extra weight in the nose to balance boat.
Posted: Mon Sep 09, 2024 4:44 pm
by Jimmyt
Be Free wrote: ↑Tue Sep 03, 2024 12:02 pm
When mine spun, I could not get it to slip by hand.
Posted: Sun Sep 15, 2024 10:15 am
by Macsailing
So, in continuing this rough water vane.
What does it mean that the 26m is stable to 90 degrees? I have seen this on other posts.
Posted: Sun Sep 15, 2024 12:06 pm
by NiceAft
Only if the ballast is FULL.
You also don’t wish to be there, and you best have a plan if you do get there.
I have sailed my
well in excess of 45 degrees;; it was fun. I have no interest in 90
Posted: Sun Sep 15, 2024 9:52 pm
by Macsailing
Well if 90 degrees means the top of the mast is just about touching the water, i agree i dont want to be there either...
Posted: Mon Sep 16, 2024 7:36 am
by Be Free
Macsailing wrote: ↑Sun Sep 15, 2024 10:15 am
It means that the boat can heel 90 degrees (mast parallel to the water) and it will return to an upright position once the force is removed.
As other posters have mentioned, this is only true if the water ballast is full.
This is neither normal, desirable, nor enjoyable.
Posted: Tue Sep 17, 2024 9:24 am
by Macsailing
Thanks, not sure how you would even stay in the boat past 45 degrees, now thai know what that means...
Posted: Tue Sep 17, 2024 9:48 am
by NiceAft
Macsailing wrote: ↑Tue Sep 17, 2024 9:24 am
Staying in the boat beyond 45 degrees is not difficult. your speed is practically zero, but it is fun doing a balancing act with the boat. Anything bellow, which is not fastened down, will be tossed around. The most fun is watching the looks on power-boaters faces; they think you are about to capsize. This is not for everyone. i am lucky. My wife gets a kick out of it.
Posted: Wed Sep 18, 2024 8:46 am
by Be Free
Just brace your feet against the lee (downhill) side of the cockpit. It's pretty easy up to 45 degrees or so. I don't recommended it, but that's how you do it. It's rough on the sails, the rigging and the crew and you will be barely moving to windward. The juice is not worth the squeeze.
My 90 degree debacle was a microburst that I caught near a thunderstorm. I was able to release the main but the pressure on the jib was too much to get the cleat to release in time. The boat was dragging the the main in the water while being spun at least 360 degrees by the jib. I tore the rotator cuff in my right shoulder yanking up on the jib sheet trying to get it to release. As soon as the storm passed the boat came right back up on her feet. The whole thing probably only lasted 15 or 20 seconds but it sure seemed longer.
Posted: Wed Sep 18, 2024 8:54 am
by Be Free
Ray,
I prefer the looks of the power boaters when I come by at full throttle, up on a plane.
It's even better when they have been following me through a no-wake zone and I take off at the end. I may not be faster than they are but I'm
way faster than they thought I'd be!
Posted: Wed Sep 18, 2024 5:19 pm
by NiceAft
Be Free wrote: ↑Wed Sep 18, 2024 8:54 am
Ray,
That works too.
