26X trailer Lug bolt
Mike Ford
Post by Mike Ford »
I need to replace a Lug bolt on a 2002 26X trailer. Anybody know of a source for a replacement bolt? :macx:
Bawgy
Post by Bawgy »
NAPA
Mike Ford
Post by Mike Ford »
What is the NAPA part number?
Bawgy
Post by Bawgy »
I dont know I dont work for them :D :D Just take one of them in and match it up. Thats what I would try first
Also Call theses guys they are very helpful
http://www.redneck-trailer.com/
http://www.redneck-trailer.com/2006/B/B42-B46.pdf
Post by Frank C »
Any RV or camper supply house will have standard (Ford) replacement trailer hubs. Right next to the hubs you should see individual parts for same ... brakes, bearings, lugs ... everything.
Bobby T.-26X #4767
Post by Bobby T.-26X #4767 »
i broke one off when I replaced/rebuilt my hubs last year.
once everything was apart, i removed a "clean one" as a means to match at NAPA and CarQuest.
Bob T.
"DāBob"
Dinghy Motor: '06 2.5-Suzuki
Retcoastie
Post by Retcoastie »
Its a 1/2" 20 thread nut. Basic Ford, junkyard or neighbor!!!!!!
Post by Kelly Hanson East »
Has anyone gone stainless on these bolts and nuts to stop them from freezing up
(Lets not debate the lube vs non-lube thing again)
I don't think so, Steph - I don't think they make stainless lug nuts. But then I'm also not a huge proponent of stainless, particularly when you have to marry it with non-stainless (the studs)... that combo sometimes tends to gall or seize. I'd just use plain nuts, and if I was concerned about them rusting I'd just smear some axle grease on them once they're tightened, or even spray them with cosmolene (or CRC Marine Heavy Duty Corrosion Inhibitor).
Hardcrab
Post by Hardcrab »
I was thinking of replacing both the studs and nuts with SS, but I have not seen this done.
I think we have a subscription to Cosmolene magazine at home..
:P
Mike Ford
Post by Mike Ford »
Has nobody personally ordered replacement lug bolts and knows what part number to get from where! I have already gotten two different wrong lug bolts from Advanced Auto (splined part was not a correct match) after having them match the old lug, been told by a Napa guy he needed a part number, and ordered lug bolts from "Trailer Parts Superstore" that again had wrong diameter on the splined part. :?
Kelly Hanson East wrote:I think we have a subscription to Cosmolene magazine at home..
:P
Yeah, you ought to see those Cosmolene girls... woo hoo!
LOUIS B HOLUB
Post by LOUIS B HOLUB »
I once sheared all my lug bolts off enroute to the Bay, and 3 major Auto Parts stores didnt have correct size replacements. Fortunately, a trailer sales & Mfg. had them, and inserted them in the hub.
I purchased an extra set, just in case (hopefully never necessary). But, I recommend having "extras" on hand.
Louis - can you pull your paperwork and send Mike those numbers maybe??
Or write them on a Cosmolene blow-up, I mean, blow-in card and mail it to him??
:D
