Langg
Posts: 23 Joined: Tue May 27, 2008 9:05 am
Location: Nashville TN. 2003 26M, Yamaha T50, "Chasing The Wind"
Post
by Langg » Wed May 28, 2008 1:23 pm
Did the 2003
come with a cap on the mast
and is it supposed to have a back stay?
The broker told me no on both. Is this true?
parrothead
Posts: 426 Joined: Sun Mar 06, 2005 7:25 am
Post
by parrothead » Wed May 28, 2008 1:38 pm
None of the
models have had a backstay.
My '05 came with a white plastic mast cap.
Posts: 8343 Joined: Thu Oct 11, 2007 12:01 pm
Post
by Russ » Wed May 28, 2008 2:05 pm
My '08 M has a plastic cap on the mast. Not much to it actually but it fits over the top and probably keeps rain and birds out. I had to drill the rivets out to get it off.
No to the backstay. Just shrouds raked aft.
This freaks me out as my last boat had a backstay and I'm constantly reaching for the invisible stay.
This is what it looks like when I removed the cap
Bill Earnhardt
Posts: 58 Joined: Sun Jun 25, 2006 3:44 pm
Post
by Bill Earnhardt » Wed May 28, 2008 5:27 pm
I had an o3, it had a mast cap
Langg
Post
by Langg » Thu May 29, 2008 6:30 am
Ok Thanks...i thought they probably came with some kind of cap.
wasnt sure about the backstay....seems like you would need one.
c130king
Posts: 2730 Joined: Sun Nov 05, 2006 5:30 pm
Post
by c130king » Thu May 29, 2008 6:55 am
Does the 2003
have the rotating mast? Not sure when the rotating mast came out. A "normal" backstay won't work with a rotating mast...will it?
Some here have built running backstays to go with rotating masts.
My
has a black mast cap...which I have cracked and repaired with duct tape.
Langg
Post
by Langg » Thu May 29, 2008 2:28 pm
Yes it does have a rotating mast
Scott
Posts: 1654 Joined: Tue May 18, 2004 12:46 pm
Post
by Scott » Thu May 29, 2008 3:24 pm
tangentair
Posts: 1234 Joined: Mon Jan 22, 2007 11:59 am
Post
by tangentair » Thu May 29, 2008 4:25 pm
What size is your garage door? There is no way I could ever get my boat inside even with the mast laying on the floor. Nice pictures by the way.
PeteC
Posts: 243 Joined: Tue Mar 02, 2004 7:06 pm
Post
by PeteC » Fri May 30, 2008 9:15 am
What are the advantages of having a mast cap?
Should I make one for my X (boat, not wife)?
Posts: 2441 Joined: Thu Apr 13, 2006 7:32 am
Post
by K9Kampers » Fri May 30, 2008 9:32 am
So your masthead doesn't get sunburned!
RickJ
Posts: 292 Joined: Mon Oct 01, 2007 2:39 pm
Sailboat: MacGregor 19
Post
by RickJ » Fri May 30, 2008 2:00 pm
PeteC wrote: What are the advantages of having a mast cap?
I suspect the reason the factory put one on the M is to stop the foam getting saturated. The X mast is empty, so any rain will just run out the bottom.
The usual reason for making a cap for an X is to mount things on top of the mast, e.g. light, wind sensor, antenna, etc.
Cheers, Rick
Post
by K9Kampers » Fri May 30, 2008 2:20 pm
In addition to what Rick said, having a cap on an X mast will help keep bugs, bees & birds from making a home in there. While beneficial for mounting stuff, the same can be accomplished without.
Scott
Post
by Scott » Fri May 30, 2008 4:44 pm
Tangent, Thass' funny. The boat isnt under the mast BTW.
As for the need or benefit, It makes a good place to mount stuff and next time I work on it there wont be 3 petrified birds in there.
