Our Mac 26M is kept on a buoy field on the east shore of Lake Tahoe in Zephyr Cove. Ain't called "Zephyr" for no reason !
We now have an anchor sail installed which has reduced the boat's swing when on the anchor buoy but the boat's rolling in those big waves is still swinging the mast from side to side as the boat rolls. (Oh, and we have a 16' mooring line..if that factors into the equation.)
We've looked at the permanently mounted Magma Rock 'N Roll Stabilizer outrigger system [not clear if 1) you'd use one or two of them on opposite sides of the hull 2) they are strong enough to leave deployed when the M26 is left unattended for days on the mooring buoy]. Pricey i.e. $500/stabilizer & outrigger ! but is this the best and only realistic answer?
or can we do something a lot more economical with the orange rocker stoppers and a piece of PVC pipe mounted perpendicularly across the deck with a set of stoppers/mushroom anchor snapped onto each end of the pipe? We'd appreciate any specific install ideas on how to attach such a pipe so that it can be installed on the the deck when we moor the M26 and easily removed & stored (as well as the weighted rocker stopper lines hung off each ends) when we go out sailing.
