Clemo,
my kite was also made by Ray Brown over in Adelaide. Good quality materials and sets real well
Naturally enough its blue with a bit of white in the middle to match the fast blue hull.
Lease,
when it comes to sailing down wind, I can keep up with much faster boats and do pretty good in a wider range of angles. The interesting one is when running square to the wind, where in light airs the admiral uses the boat hook as a whisker pole and we run gull wing.
After having many classes of boats over the years and now using assymetricals on our trailable and skiff the admiral now refuses to go near a boat that needs a pole set.
As for gybing, the luff of the kite is outside the forestay and is gybed the same as you would if you were gybing with a headsail. The main difference is that the gybe is done slower, float the kite forward a bit, wait for the kite to collapse, then pull kite around to the other side. The only time it gets messy is if the admiral gybes a bit quick and the kite starts powering up before its all transferred to the new side. It's pretty easy really.
To keep it easy I also have the kite halyard exiting the mast 400mm above the forestay attachment point. This gives a bit of seperation between the kite and jib to help reduce the chance of wrapping one around the other. It's also not so high that I'm worried that the kite will damage the mast (no backstay to support the forward pulling effort).
Correct me if I'm wrong, but I'm taking a guess that when the
made its way to Australia there was no option for an assymetrical. If that's the case, we made need to change the racing options to something like:
to use Double luff traditional kites only (size would then need to be discussed), and
to use the cruising assymetrical kites only
I'm open to differnent options.
Brian
