Backstay tension
rick retiree
Backstay tension
Have been using a turnbuckle to set tension on backstay. This is how it was rigged when I bought the 2001
used. Does anyone on this forum have a small block & tackle that they could recommend? Thanks
Re: Backstay tension
use your cheap Mac mainsheet as a backstay adjust as I did then as above buy one of these I use one as my mainsheet & the other as a preventerbscott wrote:I use a Garhauer 4:1 Vang which works.
Bob
http://i844.photobucket.com/albums/ab1/ ... 010087.jpg
Cheers J
- sbods
Highlander wrote:use your cheap Mac mainsheet as a backstay adjust as I did then as above buy one of these I use one as my mainsheet & the other as a preventerbscott wrote:I use a Garhauer 4:1 Vang which works.
Bob
Cheers J
Ooooooooh...shiney!
Nice kit
